Overzicht distributieriem intervallen Audi/VW
Howto's en handleidingen
JohnM
15 jan 2020, 18:03 1 x
From the Brexiteers,
toon9
Member
8 May 2008
• Add bookmark
• #6
Reply from Audi Technical Services 1.4 Tdi 04' plate A2.
I thought I'd share this reply I got from Audi UK regarding the cambelt change interval on my A2. They checked the chassis number for my car and this is what they came back with.
I also had it susequently confirmed verbally - as I followed up the email query by calling the Technical department today.
Hope it helps. Here goes :
"Dear Mr R........
Thank you for your e mail dated 2 May 2008, regarding the service and cambelt on your A2. Please accept my apologies for the delay in replying.
I have spoken to the Technical Department who advise that the cambelt requires changing before 80,000 miles and the cambelt and tensioner will require changing before 160,000 miles. The vehicle needs servicing every two years or 20,000 miles.
I hope this information is helpful and if you have any further queries please contact the Customer Services Department on the telephone number below.
Kind regards
XXXXXX XXXXXX
Correspondence Advisor
Audi Customer Services
Tel: 0800 699888 Ext. #####
Fax: 0113 3932585
E-Mail: xxxx.xxxxx@audi.co.uk
Volkswagen Group United Kingdom Limited
Registered Office: Yeomans Drive, Blakelands, Milton Keynes, MK14 5AN Registered in England No: 514809.
This email and any files transmitted with it are confidential and it
may be privileged. It is intended solely for the use of the
individual or entity to whom it is addressed. If you have received
this in error, please contact the sender and delete the material immediately"
Like Reply
Report
S
steve hughes
Member
Steefa2
31 okt 2023, 10:07 0 x
Hoi,
Binnenkort komt er een A2 en heb er een op het oog waar weliswaar dedistributieriem van moet worden vervangen. Heeft iemand ervaring met een goede garage die A2's ook leuk vind, omgeving Arnhem.
Hoor het graag!
Duckman
31 okt 2023, 11:20 1 x
Geen specifieke A2 garage maar ik ben erg te spreken over Dorpsgarage Elshof (ik ga altijd naar Brummen, ze hebben meerdere vestigingen). Doe het meeste zelf aan de auto maar als er iets gedaan moet worden wat ik niet kan ga ik daar naar toe. Één van de weinige garages waarvan ik niet het gevoel heb dat ze me op proberen te lichten.....
audiJan
31 okt 2023, 14:57 0 x
Steefa2 schreef:
31 okt 2023, 10:07
Hoi,
Hoor het graag!
Wat wil je vervangen hebben door welke kwaliteit terug geplaatst met welke garantie.
Dat zou de vraag kunnen zijn bij jou gewenste garage.
Vw motor is het zelfde
